Form Logic - Play Sound
#1
I see there is a way to play a custom sound in form logic, can you give some guidance? My app is designed where the user scans a barcode, it retrieves a description and a UOM and then they scan a qty barcode. I would like to have a custom wav file so they know when they are ready for the qty with out looking at the screen.
Thank you
#2
If you are using an Android device you can just put the name of the wav file (IE: Test.wav) in the Action Value field, then copy the wav file to the root of the Android file system (This would be at the same level that you see the tracerplus10 folder under).
For Windows Mobile based devices it is the same process. wav file will get copied to the root of the device folder.
Let us know if you have any questions on this.
