Andrew S
I have a field (a) that's displayed sometimes. The previous field (b) has a 'go to field' of field (a). Field (a) has a 'go to field' of field (c). This is fine when field (a) is displayed (so the cursor moves to (a) then (b) then (c) and then back to (a)). However, if field (b) is set to visible=false, the cursor doesn't move from (a) to (c) as it should - instead it gets moved to the invisible field (b).
Should the behavior not be that if a 'go to' field is set to visible=false, the cursor should automatically go to the value of the visible=false field, thus effectively skipping the invisible=false field?
