Chris Gaertner
New TracerPlus 9 Standard for Windows Mobile user, was TracerPlus palm user until PDA died this week.
Created project to perform same Session functions as TPP app, but can't check Enable lookups on the Lookup Options tab because it is not enabled. What do I need to do to enable that checkbox?
During the creation of the project, I was able to check this box on one Session2 field, but then realized that it needed to be checked on a different field, but then I couldn't check it on any field in any Session.
The manual doesn't describe why this check box would be disabled or how to enable it.
