Improve Error Logging and Error Triggers
Jeremy Farber
Right now the error log tells you the ip address but not the handheld. Add the device id also it does not tell you which profile it just tells you process. Add the profile.
Make it so that if an error is triggered an email can be sent out using SMTP. If a sync error takes place and the user doesn't see it the admin has no way of knowing unless they check.
