Hello
We are looking at TracerPlus at the moment, we have numerous barcode requirements and TracerPlus seems like what we have been looking for for a long time.
We will mainly need barcode apps that use data from our SOP database, but we do not control that database and cannot add more fields to it, so for any data collected via TracerPlus we need to store it in to a separate database.
Is below possible?
Fields in TracerPlus -
Barcode #
Order No #
Item No #
Item Description
Signature
Only Barcode # and Signature will be editable, Barcode # will be filled using barcode reader.
Order No #, Item No # and Item Description can be fetched using scanned Barcode # from our SOP database and shown in TracerPlus mobile client using SQL query, then once signature is captured all fields (including ones fetched from SOP database) are inserted to a separate database
Is this sort of idea possible?
Is below possible?
Barcode #
Order No #
Item No #
Item Description
Signature
