R racon New Member Nov 28, 2015 #1 I have 1 primary connect and 5 satellite connect seats. Will all mobile client devices be able sync using any of the connect seats? Thanks Racon
OliverR Member Dec 2, 2015 #2 Hi Racon. Maybe this link to a TracerPlus Knowledgebase article is helpful for you. A mobile client can sync (unlimited) if: TracerPlus Connect on the PC (whether that be a Primary or a Satellite) is registered TracerPlus on the mobile client is registered (you need a seperate Mobile license for this, it is not included with a Connect license) The Device ID of the mobile client is listed in the TracerPlus Connect installation that's doing the syncing (in Connect, menu Tools -> Registration). If those conditions are met, then yes, your mobile client should be able to sync with all your Connect installations, both Primary and Connect.
