Russ Pease
Managing printers is very tedious the way it is presently done.
It would simplify things if the printer Connection preferences were a Project setting. Then these printer settings would only have to be setup once.
The selecting of the report would be stay as it is as a session setting.
With the Printer and Reports settings locked together you can easily create a situation where you need 15 or 20 different print buttons to take care of all the possibilities.
