Several Connect Suggestions
Jeremy Farber
  • Create a setting that will allow for default message size. It defaults to 10 now and then you have to change it. Allow for changes but put something under preferences so that it can be set to something other than 10.
  • Make moving Profiles in the project explorer easier - If you want to move a profile up, you have to click it then click the up arrow and then click it again then click the up arrow. Lots of clicks....Idea - one click on the profile then click the arrow to move it up as many times as you want.
  • Moving a profile up does not reorder the tabs at the top. If you want them to be in the same order you have to save close then reopen.
