You could do this through our Custom SQL variable (or form logic) options. If you create a SELECT statement that retrieves the last number used, you could then use a TracerPlus calculated field to add 1 to it.
If you just need to use an incremental field, you can also look at some of the other variable options. There is an autonumber option that may work well for you.
